Links
Robot specifications
xArm 5
xArm 6
xArm 7
Lite 6
850
Maximum Speed: 180°/s
Working Range:
Joint 1
±360°
Joint 2
-118°~120°
Joint 3
-225°~11°
Joint 4
-97°~180°
Joint 5
±360°
Working Range:
Joint 1
±360°
Joint 2
-118°~120°
Joint 3
-225°~11°
Joint 4
±360°
Joint 5
-97°~180°
Joint 6
±360°
Working Range:
Joint 1
±360°
Joint 2
-118°~120°
Joint 3
±360°
Joint 4
-11°~225°
Joint 5
±360°
Joint 6
-97°~180°
Joint 7
±360°
Working Range:
Joint 1
±360°
Joint 2
±150°
Joint 3
-3.5°~300°
Joint 4
±360°
Joint 5
±124°
Joint 6
±360°
Working Range:
Joint 1
±360°
Joint 2
±132°
Joint 3
-242°~3.5°
Joint 4
±360°
Joint 5
±124°
Joint 6
±360°
Range of various motion parameters of the robotic arm
xArm5/6/7
Lite 6
850
Text
TCP Motion
Joint Motion
Speed
0~1000mm/s
0~180°/s
Acceleration
0~50000mm/s²
0~1145°/s²
Jerk
0~100000mm/s³
0~28647°/s³
Text
TCP Motion
Joint Motion
Speed
0~500mm/s
0~180°/s
Acceleration
0~50000mm/s²
0~1145°/s²
Jerk
0~100000mm/s³
0~28647°/s³
Text
TCP Motion
Joint Motion
Speed
0~1000mm/s
0~180°/s
Acceleration
0~50000mm/s²
0~1145°/s²
Jerk
0~100000mm/s³
0~28647°/s³
Note:
1. In the TCP motion (Cartesian space motion) commands, if a motion command involves both position transformation and attitude transformation, the attitude rotation speed is generally calculated automatically by the system. In this situation, the specified speed parameter is the maximum linear speed, range from 0 to 1000 mm/s.
2. When the expected TCP motion only changes the attitude (roll, pitch, yaw), with position (x, y, z) remains unchanged, the specified speed is the attitude rotation speed, so the range 0 to 1000 corresponds to 0 to 180 °/s.
