Links
Motion Parameter Setting(31-40)
Set the jerk of the Cartesian space translation
Register:31 (0x1F)
00 01 00 02 00 05 1F 00 00 FA 44
Request Description
//00 05 U16, Length
//1F U8, Register
//00 00 FA 44 FP32, TCP Jerk=2000 mm/s³
00 01 00 02 00 04 1F 00 00 01
Response Description
//00 04 U16, Length
//1F U8, Register
//00 01 U16, The number of commands in the buffer
Set the maximum acceleration of the Cartesian space translation
Register:32 (0x20)
00 01 00 02 00 05 20 00 80 BB 45
Request Description
//00 05 U16, Length
//20 U8, Register
//00 80 BB 45 FP32, Maximum acceleration=6000 mm/s²
00 01 00 02 00 04 20 00 00 01
//00 04 U16, Length
//20 U8, Register
//00 01 u16, The number of commands in the buffer
Set the joint space jerk
Register:33 (0x21)
00 01 00 02 00 05 21 00 40 1C 46
Request Description
//00 05 U16, Length
//21 U8, Register
//00 40 1C 46 FP32, Jerk=10000 rad/s³
00 01 00 02 00 04 21 00 00 01
//00 04 U16, Length
//21 U8, Register
Set joint space max acceleration
Register:34 (0x22)
00 01 00 02 00 05 22 00 00 C8 43
Request Description
//00 05 U16, Length
//22 U8, Register
//00 00 C8 43 FP32, Jerk=10000 rad/s³
00 01 00 02 00 04 22 00 00 01
//00 04 U16, Length
//22 U8, Register
Set TCP offset
Register:35 (0x23)
The above operations will terminate the ongoing movement of the robotic arm and clear the cache commands, which is the same as the STOP state.
00 01 00 02 00 19 23 00 00 C8 43 00 00 00 00 00 00 48 43 DB 0F 49 40 00 00 00 00 00 00 00 00
Request Description
//00 19 U16, Length
//23 U8, Register
//00 00 C8 43 FP32, x=400 mm
//00 00 00 00 FP32, y=0 mm
//00 00 48 43 FP32, z=200 mm
//DB 0F 49 40 FP32, roll=π
//00 00 00 00 FP32, pitch=0
//00 00 00 00 FP32, yaw=0
00 01 00 02 00 02 23 10
//00 02 U16, Length
//23 U8, Register
//10 U8, State
Set TCP payload
Register:36 (0x24)
00 01 00 02 00 11 24 00 00 80 3F 00 00 C8 43 00 00 00 00 00 00 48 43
Request Description
//00 11 U16, Length
//24 U8, Register
//00 00 80 3F FP32, Payload=1kg
//00 00 C8 43 FP32, Payload center of mass X=400mm
//00 00 00 00 FP32, Payload center of mass Y=0
//00 00 48 43 FP32, Payload center of mass Z=200mm
00 01 00 02 00 02 24 20
//00 02 U16, Length
//24 U8, Register
//20 U8, State
Set collision detection sensitivity (System reset)
Register:37(0x25)
00 01 00 02 00 02 25 04
Request Description
//00 02 U16, Length
//25 U8, Register
//04 U8, Detect sensitivity=4
00 01 00 02 00 02 25 10
//00 02 U16, Length
//25 U8, Register
//10 U8, State
Set teaching sensitivity for manual mode (System reset)
Register:38(0x26)
00 01 00 02 00 02 26 04
Request Description
//00 02 U16, Length
//26 U8, Register
//04 U8, Teach sensitivity=4
00 01 00 02 00 02 26 10
//00 02 U16, Length
//26 U8, Register
//10 U8, State
Delete the current system configuration parameters
Register:39 (0x27)
00 01 00 02 00 01 27
Request Description
//00 01 U16, Length
//27 U8, Register
00 01 00 02 00 02 27 10
//00 02 U16, Length
//27 U8, Register
//10 U8, State
Save the current system configuration parameters
Register:40 (0x28)
00 01 00 02 00 01 28
Request Description
//00 01 U16, Length
//28 U8, Register
00 01 00 02 00 02 28 10
//00 02 U16, Length
//28 U8, Register
//10 U8, State
