Other Robotic Arm Function(51-70)
Register:51 (0x33)
Set the gravity direction for correct torque compensation and collision detection. After modification, it shall call the save_conf () function or refer to Register: 40(28) to save the setting, otherwise it will be invalid after reboot.
00 01 00 02 00 0D 33 00 00 00 00 00 00 00 00 00 00 80 BF
//00 0D U16, Length
//33 U8, Register
//00 00 00 00 FP32, Gravity direction vector X=0 base coordinate system
//00 00 00 00 FP32, Gravity direction vector Y=0 base coordinate system
//00 00 80 BF FP32, Gravity direction vector Z=-1 base coordinate system
00 01 00 02 00 02 33 10
Register:52 (0x34)
C35 Set the boundary range of the safety fence in the three-dimensional space. If TCP of the robotic arm exceeds this boundary, error C35 of the Control Box will be triggered.
00 01 00 02 00 19 34 58 02 00 00 C8 00 00 00 F4 01 00 00 64 00 00 00 58 02 00 00 C8 00 00 00
//00 19 U16, Length
//34 U8, Register
//58,02,00,00 FP32, Cartesian boundary value x+ =600 mm
//C8,00,00,00 FP32, Cartesian boundary value x- =200 mm
//F4,01,00,00 FP32, Cartesian boundary value y+ =500 mm
//64,00,00,00 FP32, Cartesian boundary value y- =100 mm
//58,02,00,00 FP32, Cartesian boundary value z+ =600 mm
//C8,00,00,00 FP32, Cartesian boundary value z- =200 mm
00 01 00 02 00 02 34 10
Register:53 (0x35)
00 01 00 02 00 01 35
00 01 00 02 00 51 35 00 01 01 2C 00 64 01 2C FF F6 01 2C 00 32 00 00 C8 42 DB 0F 49 40 DB 0F C9 C0 DB 0F C9 40 15 C6 03 C0 91 0A 06 40 CE 53 7B C0 68 96 44 3E DB 0F C9 C0 DB 0F C9 40 35 B3 D8 BF DB 0F 49 40 DB 0F C9 C0 DB 0F C9 40 00 00 00 00 00 00 00 00 01 01
//00 51 U16, Length
//35 U8, Register
//10 U8, State
//10 U8, State
//00 U16, The state of Reduce mode: 0-OFF; 1-ON
//01 2C 00 64 01 2C FF F6 01 2C 00 32
int16*6, safety boundary
[x_max=300, x_min=100, y_max=300, y_min=-10, z_max=300, z_min=50]
//00 00 C8 42 FP32, Max TCP speed=100mm/s
//DB 0F 49 40 FP32, max Joint speed=180 °/s
//DB 0F C9 C0 DB 0F C9 40 15 C6 03 C0 91 0A 06 40 CE 53 7B C0 68 96 44 3E DB 0F C9 C0 DB 0F C9 40 35 B3 D8 BF DB 0F 49 40 DB 0F C9 C0 DB 0F C9 40 00 00 00 00 00 00 00 00
FP32*7, Joint range: [J1_min, J1_max, …, J7_min, J7_max]
//01 U8, The state of Safety Boundary: 0- OFF; 1-ON
//01 U8, The state of Collision Rebound: 0- OFF; 1-ON
Register:55 (0x37)
Estimate the joint torque based on current and theoretical model, which is for reference only
00 01 00 02 00 01 37
00 01 00 02 00 1E 37 00 17 37 00 00 00 00 00 2A C5 5B C1 79 A4 C5 C0 00 00 00 00 87 A3 E9 BF 00 00 00 00 00 00 00 00
//00 1E U16, Length
//37 U8, Register
//00 00 00 00 FP32, Theoretical torque of joint1 = 0
//2A C5 5B C1 FP32, Theoretical torque of joint2 = -13.7 N.m
//79 A4 C5 C0 FP32, Theoretical torque of joint3 = -6.17 N.m
//00 00 00 00 FP32, Theoretical torque of joint4 = 0
//87 A3 E9 BF FP32, Theoretical torque of joint5 = -1.83N.m
//00 00 00 00 FP32, Theoretical torque of joint6 = 0
//00 00 00 00 FP32, Theoretical torque of joint7 = 0
Register:58 (0x3A)
00 01 00 02 00 39 3A C2 F5 48 C0 C2 F5 48 40 33 33 03 C0 8F C2 05 40 C2 F5 48 C0 C2 F5 48 40 5C 8F 42 BE 47 E1 7A 40 C2 F5 48 C0 C2 F5 48 40 EB 51 D8 BF C8 00 00 00 C2 F5 48 C0 C2 F5 48 40
//00 39 U16, Length
//3A U8, Register
//C2 F5 48 C0 C2 F5 48 40 FP32, J1_min = -3.14rad,J1_max = 3.14rad
//33 33 03 C0 8F C2 05 40 FP32, J2_min = -2.05rad,J2_max = 20.9rad
//C2 F5 48 C0 C2 F5 48 40 FP32, J3_min = -3.14rad,J3_max = 3.14rad
//5C 8F 42 BE 47 E1 7A 40 FP32, J4_min = -0.19rad,J4_max = 3.92rad
//C2 F5 48 C0 C2 F5 48 40 FP32, J5_min = -3.14rad,J5_max = 3.14rad
//EB 51 D8 BF C8 00 00 00 FP32, J6_min = -1.69rad,J6_max = 3.14rad
//C2 F5 48 C0 C2 F5 48 40 FP32, J7_min = -3.14rad,J7_max = 3.14rad
00 01 00 02 00 02 3A 00
Register: 59 (0x3B)
Set the safety boundary in three-dimensional space. If the TCP of the robot exceeds this boundary, error C35 will be triggered.
00 01 00 02 00 02 3B 00
Register:60 (0x3C)
00 01 00 02 00 02 3C 00
00 01 00 02 00 02 3C 10
Register:61 (0x3D)
00 01 00 02 00 02 3D 00
Register:62 (0x3E)
00 01 00 02 00 0A 3E 74 65 73 74 2E 74 72 61 6A
00 01 00 02 00 02 3E 00
Register:63 (0x3F)
00 01 00 02 00 0A 3F 74 65 73 74 2E 74 72 61 6A
00 01 00 02 00 02 3F 00
Register:64 (0x40)
00 01 00 02 00 09 40 00 00 00 01 00 00 00 01
00 01 00 02 00 02 40 00
Register:65 (0x41)
00 01 00 02 00 01 41
00 01 00 02 00 03 41 00 00
Register: 66 (0x42)
00 01 00 02 00 02 42 00
Register: 67 (0x43)
00 01 00 02 00 01 43
00 01 00 02 00 72 43 00 00 00 00 00 00 80 85 43 00 00 00 00 00 00 00 00 FD 44 B1 BF 00 00 00 00 DB 0F C9 BF 00 00 00 00 FD 44 B1 3F 00 00 00 00 00 00 00 00 49 BE 90 43 00 00 00 00 00 40 AB 43 DB 0F C9 BF 00 00 9B 42 00 00 00 00 00 00 00 00 DB 0F C9 3F 00 00 00 00 00 00 00 00 00 00 C2 42 DB 0F C9 BF 00 00 98 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
//00 72 U16, Length
//43 U8, Register
Note:
4 float parameters per joint
A total of 112 bytes, 28 floating-point data,
only the first 24 floating-point data of the xArm6 are valid data
T2_offset = -atan(284.5/53.5) = -1.3849179 (-79.34995°)
T3_offset = atan(284.5/53.5)+atan(0.3425/0.0775) = 2.7331843 (156.599924°)
a2 = sqrt(284.5^2+53.5^2) = 289.48866
T4_offset = -atan(342.5/77.5) = -1.3482664 (-77.249974°)
a3 = sqrt(77.5^2+342.5^2) = 351.158796
For example: xArm6 SN:XI120204201B02
//J1 d(mm):267 alpha(rad):0 a(mm):0 offset(rad):0
00 00 00 00
00 80 85 43
00 00 00 00
00 00 00 00
//J2 d(mm):0 alpha(rad):-pi/2 a(mm):0 offset(rad):T2_offset
FD 44 B1 BF
00 00 00 00
DB 0F C9 BF
00 00 00 00
//J3 d(mm):0 alpha(rad):0 a(mm):a2 offset(rad):T3_offset
FD 44 B1 3F
00 00 00 00
00 00 00 00
49 BE 90 43
//J4 d(mm):342.5 alpha(rad):-pi/2 a(mm):77.5 offset(rad):0
00 00 00 00
00 40 AB 43
DB 0F C9 BF
00 00 9B 42
//J5 d(mm):0 alpha(rad):pi/2 a(mm):0 offset(rad):0
00 00 00 00
00 00 00 00
DB 0F C9 BF
00 00 00 00
//J6 d(mm):97 alpha(rad):-pi/2 a(mm):76 offset(rad):0
00 00 00 00
00 00 C2 42
DB 0F C9 BF
00 00 98 42
//J7 Null
00 00 00 00
00 00 00 00
00 00 00 00
00 00 00 00
Register: 68 (0x44)
00 01 00 02 00 73 44 00 00 00 00 00 00 80 85 43 00 00 00 00 00 00 00 00 FD 44 B1 BF 00 00 00 00 DB 0F C9 BF 00 00 00 00 FD 44 B1 3F 00 00 00 00 00 00 00 00 49 BE 90 43 00 00 00 00 00 40 AB 43 DB 0F C9 BF 00 00 9B 42 00 00 00 00 00 00 00 00 DB 0F C9 3F 00 00 00 00 00 00 00 00 00 00 C2 42 DB 0F C9 BF 00 00 98 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
//00 73 U16, Length
//44 U8, Register
Note:
00 00 00 00
00 80 85 43
00 00 00 00
00 00 00 00
FD 44 B1 BF
00 00 00 00
DB 0F C9 BF
00 00 00 00
FD 44 B1 3F
00 00 00 00
00 00 00 00
49 BE 90 43
00 00 00 00
00 40 AB 43
DB 0F C9 BF
00 00 9B 42
00 00 00 00
00 00 00 00
DB 0F C9 BF
00 00 00 00
00 00 00 00
00 00 C2 42
DB 0F C9 BF
00 00 98 42
//J7 Null
00 00 00 00
00 00 00 00
00 00 00 00
00 00 00 00
//00 U8,Set flag
0: use the set DH parameters, but do not save to the configuration file
1: Use the set DH parameters and save them to the configuration file
2: Use the set DH parameters and delete the configuration file
3: Use the default DH parameters, but do not delete the configuration file
4: Use the default DH parameters and delete the configuration file
00 01 00 02 00 02 44 00
It needs to be parsed according to different registers
Register: 69 (0x45)
00 01 00 02 00 01 45
00 01 00 02 00 2B 45 00 17 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C2 B8 B2 3E 58 A0 0B 41 00 00 00 00
//00 2B U16, Length
//45 U8, Register
//17 U8,
Current execution motion instruction register:
0x15: Cartesian linear motion
0x16: Linear motion with arc blending
0x17: P2P joint movement
0x18: joint blending movement
0x19: Back to zero movement
0x1B: arc movement
0x1C: Linear motion in tool coordinate system
0x5C: linear motion of axis angle attitude target
//00 00 00 00 FP32, Joint1=0
//00 00 00 00 FP32, Joint2=0
//00 00 00 00 FP32, Joint3=0
//00 00 00 00 FP32, Joint4=0
//00 00 00 00 FP32, Joint5=0
//00 00 00 00 FP32, Joint6=0
//00 00 00 00 FP32, Joint7=0
//C2 B8 B2 3E FP32, speed=20π/180 rad/s
//58 A0 0B 41 FP32, 500π/180 rad/s²
//00 00 00 00 FP32, motion time=0
Correspond to the report contents "60~87 Bytes" of TCP ports 30001/30002/30003
Register: 70 (0x46)
00 01 00 02 00 02 46 00
Last modified 1mo ago
