Links
Other Robotic Arm Function(81-100)
Joint velocity control
Register:81 (0x51)
Set target joint velocity for joint velocity mode (mode 4)
00 01 00 02 00 22 51 91 0A 06 3F CC CC CC BD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 CC CC 4C 3E
Request Description
//00 22 U16, Length
//51 U8, Register
//91 0A 06 3F FP32, Joint 1 target velocity: π/6 rad/s
//CC CC CC BD FP32, Joint 2 target velocity: -0.1 rad/s
//00 00 00 00 FP32, Joint 3 target velocity: 0 rad/s
//00 00 00 00 FP32, Joint 4 target velocity: 0 rad/s
//00 00 00 00 FP32, Joint 5 target velocity: 0 rad/s
//00 00 00 00 FP32, Joint 6 target velocity: 0 rad/s
//00 00 00 00 FP32, Joint 7 target velocity: 0 rad/s
//01 U8, whether all joints accelerate and decelerate synchronously: 1-True
//CC CC 4C 3E FP32, duration: 0.2s
00 01 00 02 00 02 51 00
Response Description
//00 02 U16, Length
//51 U8, Register
Cartesian velocity control
Register:82 (0x52)
Set target Cartesian linear velocity and angular velocity, for cartesian velocity control mode (mode 5)
00 01 00 02 00 1E 52 00 00 F0 41 00 00 00 00 00 00 A0 41 91 0A 06 3F 00 00 00 00 00 00 00 00 00 CC CC 4C 3E
Request Description
//00 1E U16, Length
//52 U8, Register
//00 00 F0 41 FP32, Cartesian linear velocity: Vx = 30 mm/s
//00 00 00 00 FP32, Cartesian linear velocity: Vy = 0 mm/s
//00 00 A0 41 FP32, Cartesian linear velocity: Vz = 20 mm/s
//91 0A 06 3F FP32, Cartesian angular velocity: ωx = π/6 rad/s
//00 00 00 00 FP32, Cartesian angular velocity: ωy= 0 rad/s
//00 00 00 00 FP32, Cartesian angular velocity ωz = 0 rad/s
//00 U8, is tool coordinate or not: 0-base coordinate
00 01 00 02 00 02 52 00
//00 02 U16, Length
//52 U8, Register
Relative motion
Register: 83 (0x53)
00 01 00 02 00 1E 53 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Request Description
//00 1E U16, Length
//53 U8, Register
//00 00 00 00 FP32, if TCP motion,parameter is X (mm). If joint motion,Parameter is J1 (rad)
//00 00 00 00 FP32, if TCP motion,parameter is y (mm). If joint motion,parameter is J2 (rad)
//00 00 00 00 FP32, If TCP motion,parameter is z (mm). If joint control,parameter is J3 (rad)
//00 00 00 00 FP32, If TCP motion,parameter is roll (rad). If joint motion,parameter is J4 (rad)
//00 00 00 00 FP32, If TCP motion,parameter is pitch (rad). If joint motion,parameter is J5 (rad)
//00 00 00 00 FP32, If TCP motion,parameter is yaw (rad). If joint motion,parameter is J6 (rad)
//00 00 00 00 FP32, If TCP motion,parameter is meaningless. If joint motion,parameter is J7 (rad)
//00 00 00 00 FP32, speed(mm/s, rad/s)
//00 00 00 00 FP32, acceleration(mm/s², rad/s²)
//00 00 00 00 FP32, move time(useless, just 0)
//00 00 00 00 FP32, radius(mm)
//00 U8, 0 is TCP motion, 1 is joint motion.
//00 U8, Only available in TCP motion. 0 is RPY, 1 is aixs angle.
00 01 00 02 00 02 53 00
//00 02 U16, Length
//53 U8, Register
Get the attitude represented by the axis angle
Register:91 (0x5B)
Get the current TCP pose, and use the axial angle to represent the pose of the robotic arm
00 01 00 02 00 01 5B
Request Description
//00 01 U16, Length
//5B U8, Register
00 01 00 02 00 1A 5B 00 00 00 96 43 00 00 00 00 00 00 16 43 DB 0F 49 40 00 00 00 00 00 00 00 00
//00 1A U16, Length
//5B U8, Register
//00 00 96 43 FP32, X=300mm
//00 00 00 00 FP32, Y=0 mm
//00 00 16 43 FP32, Z=150mm
//DB 0F 49 40 FP32, Rx=π rad
//00 00 00 00 FP32, Ry=0 rad
//00 00 00 00 FP32, Rz=0 rad
Linear motion with axis angle
Register:92 (0x5C)
When planning a linear motion, the target pose is expressed in terms of axis angle, which supports the absolute and relative target pose, as well as the motion options of the base coordinate system and tool coordinate system.
00 01 00 02 00 0D 5C 00 00 96 43 00 00 00 00 00 00 16 43 DB 0F 49 40 00 00 00 00 00 00 00 00 00 00 48 43 00 00 FA 44 00 00 00 00 00 00
Request Description
//00 0D U16, Length
//5C U8, Register
//00 00 48 43 FP32, motion speed=200 mm/s
//00 00 FA 44 FP32, acceleration=2000 mm/s²
//00 00 00 00 FP32, motion time, 0
//00 U8, motion reference, 0 is robot base (coordinate system), 1 is robot tool (coordinate system).
//00 U8, If the motion reference is the robot base, then 0 is absolute pose, 1 is relative pose.
00 01 00 02 00 03 5C 00 01
//00 03 U16, Length
//5C U8, Register
//00 01 U16, State
Servo_Cartesian motion (axis angle)
Register:93 (0x5D)
An interface for receiving high-frequency continuous Cartesian motion, and the posture is represented by the axis angle.
00 01 00 02 00 26 5D 00 00 96 43 00 00 00 00 00 00 16 43 db 0f 49 40 00 00 00 00 00 00 00 00 00 00 48 43 00 00 FA 44 00 00 00 00 00
Request Description
//00 26 U16, Length
//5D U8, Register
//00 00 96 43 FP32, X=300 mm
//00 00 16 43 FP32, Z=150 mm
//db 0f 49 40 FP32, Rx=π rad
//00 00 00 00 FP32, 0 i the robot base coordinate system, 1 is robot tool coordinate system.
00 01 00 02 00 02 5D 00
//00 02 U16, Length
//5D U8, Register
