Special IO commands(142-147)
Register:142(0x8E)
After the delay time has elapsed the controller digital output will be activated.
00 01 00 02 00 07 8E 00 01 00 00 40 40
00 01 00 02 00 02 8E 00
Register:143(0x8F)
After the delay time has elapsed the tool digital output will be activated.
00 01 00 02 00 07 8F 00 01 00 00 40 40
00 01 00 02 00 02 8F 00
Register:144(0x90)
Controller digital output will be activated when the robot reaches the specified area, which is valid for a single time
00 01 00 02 00 13 90 00 01 00 00 c8 43 00 00 00 00 00 00 48 43 00 00 48 42
//00 13 U16, Length
//90 U8, Register
//00 U8, Controller digital output number, 0~15, here is CO 0.
//01 U8, Digital output value, 0(low) or 1(high) , here is 1.
//00 00 c8 43 FP32, x=400mm
//00 00 00 00 FP32, y=0mm
//00 00 48 43 FP32, z=200mm
//00 00 48 42 FP32, tolerance radius, here is 50 mm.
* When the robot reaches the area (400,0,200) with the tolerance of 50 mm, controller digital outpout 0 will be set to 1(high).
*If the tolerance radius is not set, it will not work.
00 01 00 02 00 02 90 00
Register:145(0x91)
Tool digital output will be activated when the robot reaches the specified area, which is valid for a single time
00 01 00 02 00 13 91 00 01 00 00 c8 43 00 00 00 00 00 00 48 43 00 00 48 42
//00 13 U16, Length
//91 U8, Register
//00 U8, Tool digital output number, 0~1, here is TO 0.
* When the robot reaches the area (400,0,200) with the tolerance of 50 mm, tool digital outpout 0 will be set to 1(high) .
00 01 00 02 00 02 91 00
Register:146(0x92)
00 01 00 02 00 03 92 00 01
00 01 00 02 00 04 92 00 00 01
Register:147(0x93)
Controller analog output will be activated when the robot reaches the specified area, which is valid for a single time
00 01 00 02 00 14 93 00 00 00 00 c8 43 00 00 00 00 00 00 48 43 00 00 48 42
//00 14 U16, Length
//93 U8, Register
//00 U8, Controller analog output number 0~1, here is 0.
//00 00 U16, Analog output value, range 0~4095, corresponding to 0~10 V.
* When the robot reaches the area (400,0,200) with the tolerance of 50 mm, controller analog outpout 0 will be set to 0 V.
00 01 00 02 00 02 93 00
