Guide to run robotic arm at the maximum speed?
If you want to speed up the motion of UFACTORY arm, please adjust the following 2 aspects.
Take xArm Series as an example.
Firmware version: v2.0.0+
UFactory Studio version: v2.0.0+
xArm-Python-SDK version: v1.10.0+
The main parameters that affect the movement speed of xArm are: speed, acceleration, and jerk.
TCP Motion | Joint Motion | |
Speed | 1000mm/s | 0 ~ 180°/s |
Acceleration | 50000mm/s² | 1146°/s² |
Jerk | 100000mm/s³ | 28647°/s³ |
It is recommended to adjust the jerk to the maximum, which will speed up the motion of robotic arm.
Parameter adjustment via UFACTORY Studio
'Settings-General-Advanced Settings-Parameters'
Parameter adjustment via Python SDK
1) Speed: 'speed' parameter
2) Acceleration: 'mvacc' parameter
3) Jerk: set_tcp_jerk() , set_joint_jerk()
Adjust Parameters to do continuous motion.
radius > 0
wait = False
Example:
Radius>0, wait=False; Video: https://youtu.be/oX_J8RplEw4
Radius>0, wait=True; Video:https://youtu.be/wpBzt3a30L0
Radius<0, wait=False; Video:https://youtu.be/pi-5PPhPpfg
