Links
The difference between UFACTORY xArm5, xArm6 and xArm7
The purpose of this article is to describe the differences between UFACTORY xArm5, xArm6 and xArm7.
1. Specifications
xArm 5 Lite
xArm 6
xArm 7
Payload(kg)
3kg
5kg
3.5kg
Reach(mm)
700mm
700mm
700mm
Degrees of Freedom
5
6
7
Maximum Speed(m/s)
1m/s
1m/s
1m/s
Weight(kg, body only)
11.2kg
12.2kg
13.7kg
xArm 5 Lite
xArm 6
xArm 7
Maximum Speed
180°/s
180°/s
180°/s
Joint1
±360°
±360°
±360°
Joint2
-118° ~ 120°
-118°~120°
-118°~120°
Joint3
-225°~11°
-225°~11°
±360°
Joint4
-97°~180°
±360°
-11°~225°
Joint5
±360°
-97°~180°
±360°
Joint6
±360°
-97°~180°
Joint7
±360°
2. Motion Characteristics
  • Cartesian control
xArm 5 Lite: Due to the robot configuration, the actual flexible degrees of freedom of linear and circular motions in Cartesian space is 4, which is [x, y, z, yaw], similar to a SCARA manipulator with four degrees of freedom. Before initiating Cartesian control movement, it is necessary to ensure that the end flange surface of xArm5 and the base are completely parallel. If mounted on a horizontal plane, the roll and pitch should be [± 180 degrees, 0 degrees], otherwise the trajectory is likely to have no solution.
