How to solve C31 error?
UFactory version: V2.1.0+
When the actual obtained current exceeds the expected current threshold, our software will report a C31 error and stop the arm to protect it.
There are 4 reasons, please check the configs below to solve it.
1. TCP payload
Check if the TCP payload setting on 'Settings-Motion-TCP' is consistent with the actual payload.
2. High motion speed
Try to lower the speed to verify this problem.
3. Friction parameter
Check if the friction parameter is loaded successfully.
You can enter 'Settings-My Device-System Info-Robot SN', if the SN info is consistent with the SN attached to the robot base, if so the friction parameter is loaded successfully.
4. Collision sensitivity
Try to lower the 'Settings-Motion-Parameters-collision sensitivity' to verify this problem.
