How to solve C60 error?
C60: Linear speed exeed limit in ServoJ mode.
Firmware: V2.3.0+
UFactory Studio: V2.3.0+
For safety reasons, we give a TCP speed limit under ServoJ mode even for joint motion, the limit is 1200mm/s for xArm series and UF850, and 600mm/s for Lite6.
When the arm works at extended reach, the TCP speed can easily exceed the threshold. Therefore, we increase this threshold and provide a parameter to set the limit by themselves, please modify it carefully after safety evaluation.
set_linear_spd_limit_factor
get_linear_spd_limit_factor
factor*1000 = TCP speed limit, the default value is 1.2.
1.2*1000=1200mm/s for xArm/UF850, 1.2*500=600mm/s for Lite6
call save_conf() to save this config after calling set_linear_spd_limit_factor.
