How to solve S17 error?
S17: Single-turn Encoder Error
UFactory version: V2.4.0+
Status code=16
Code:S17 , Joint ID: *(can be 1~7) , status code:16
press down the E-stop button and then release.
Enter 'Settings-General-Debugging Tools-Joing', send 'H101 D0104 V1 I*' to unlock joint*, manually move joint* a little bit, and then send 'H101D0813V2I*', press down E-stop button. (This step will reset the zero position, so you need to mark the original position of joint* before moving)
release the E-stop button, move Joint* to the original position, send 'D13 I*', press down E-stop button.
Try to enable the robot again.
