2. Linear motion
1. Linear Motion
Initialization
Assume the robotic arm controller's IP address is 192.168.1.47, initialize the robotic arm.
arm=XArmAPI('192.168.1.47')
Enable
If the robotic arm is not enabled, it needs to be enabled. Once enabled, there is no need to enable it again.
Set Mode and State
After enabling, you need to set the mode and state for the robotic arm to move. The robotic arm has multiple modes; the commonly used linear motion and joint motion are both position commands, i.e., mode 0.
arm.set_mode(0)
The robotic arm can be set to various modes. Mode 0 is for motion, mode 3 is for pausing the motion, and mode 4 is for stopping the motion.
Send Position Command
In the xArm-Python-SDK, the Cartesian position is defined as x, y, z, roll, pitch, yaw. The unit for distance is millimeters (mm), and the default angle representation is degrees (°).
As an example of linear motion in Cartesian space, let the robotic arm move to point A [300,0,150,180,0,0] first, and then to point B [400,0,150,180,0,0].
arm.set_position(300,0,150,180,0,0)
arm.set_position(400,0,150,180,0,0)
Speed
In the set_position() interface for linear motion, the speed is passed with the speed parameter, and the unit is mm/s. For example, let the robotic arm move to point A [300,100,150,180,0,0] at 200 mm/s.
arm.set_position(300,100,150,180,0,0, speed=200)
Complete Example
arm = XArmAPI('192.168.1.47')
arm.set_mode(0)
arm.set_position(300,0,150,180,0,0, speed=200)
arm.set_position(400,0,150,180,0,0, speed=200)
