ReadMe_others
For Chinese version: 简体中文版说明
Important Notice:
This ReadMe is for new(Lite 6) and future UFACTORY product models other than xArm series. Here use "lite6" as example.
If you have used "xarm_ros" for xArm series before, the main differences for new UFACTROY models are:
Default namespace has changed from
xarm
toufactory
;Robot full-state report topic name has changed from
xarm_states
torobot_states
1. Simulations
1.1 Simple Rviz visualization:
The robot model will appear in Rviz window and "joint state publisher" panel can be used to adjust the posture of that robot.
1.2 Load robot model in Gazebo environment:
Gazebo will be launched and virtual robot will be mounted on a table, add_gripper
and add_vacuum_gripper
are optional arguments. However, only one end tool should be installed.
1.3 Moveit simulation:
Without Gazebo:
With Gazebo:
In the first terminal, run:
Then in another terminal:
In this way, the simulated robot in gazebo can execute planned trajectory generated by Moveit.
2. Controlling Real Robot
2.1 ROS service control:
First bring up the UFACTORY ros driver:
Then, please refer to xarm_api/xarm_msgs part, the concepts, provided services or messages are all the same except the default namespace for non-xArm series is ufactory
rather than xarm
. For example, to call the service of enabling all joints:
All the xArm services (joint/cartesian motion, velocity motion, servo motions, etc) including mode operations can be directly used on new models like Lite 6, just replace previous namespace /xarm
with /ufactory
Another difference from xArm version is the topic /xarm/xarm_states
has been changed to /ufactory/robot_states
(with default namespace attached).
2.2 Moveit control:
First make sure the robot and controller box are powered on, then execute:
add_gripper
are optional available arguments if you have installed UFACTORY provided tool accessory. Only one end tool shall be installed. Below is the network diagram from rqt_graph
output:
重要说明:
这篇ReadMe适用于UFACTORY xArm系列之外的产品(如Lite 6),本说明使用 "lite6" 作为例子。
如果您之前已经使用过 "xarm_ros" 开发 xArm 系列产品, 对于UFACTORY其他系列的ros开发,方法和操作大同小异,主要的区别在于:
默认的命名空间从
xarm
更改为ufactory
;机械臂全状态反馈的话题(topic) 名称由
xarm_states
更改为robot_states
1. 仿真
1.1 简单的Rviz可视化:
运行之后,机械臂的模型会出现在Rviz界面中,"joint state publisher" 面板可以用来调整手臂的位姿。
1.2 Gazebo环境中加载仿真模型:
Gazebo启动后, 虚拟机械臂会放置在桌子边沿位置,add_gripper
和 add_vacuum_gripper
是另外的可选参数,可以根据需要给定true
来加载UFACTORY官方的夹爪或吸头的配件模型,注意只能加载一款末端执行器。
1.3 Moveit规划仿真:
如果不使用Gazebo:
如果使用Gazebo:
打开一个终端, 执行:
然后,在另一个终端中执行:
这样,Gazebo中的虚拟手臂可以执行Moveit在Rviz界面中的规划路径。
2. 控制真实机械臂
2.1 ROS service 控制:
首先启动 UFACTORY ROS 驱动:
然后,请认真阅读和参考xarm_api/xarm_msgs 部分, 其中的概念、提供的服务和定义的消息类型都是和xarm一致的,除了默认的命名空间是 ufactory
而不是 xarm
。举例来说,对于非xArm系列如Lite6手臂,调用全部关节使能服务的方法为:
所有xArm适用的服务(关节/笛卡尔运动, 速度模式运动, servo运动等等)以及 模式操作都可以使用在Lite 6 型号中, 调用方法很简单,将之前说明中的/xarm
命名空间替换为/ufactory
就好。
另一个值得注意的变化是xArm系列使用的话题 /xarm/xarm_states
被修改为 /ufactory/robot_states
(已带上默认命名空间)。
2.2 Moveit 规划控制:
首先确认手臂已经正确上电, 然后执行:
add_gripper
来加载UFACTORY官方的夹爪或吸头的配件模型,注意只能加载一款末端执行器。下图是来自rqt_graph
输出的网络结构示意图:
