xarm_msgs
The services and messages defined in this package is based on the programming API. To offer a way for users to call them by ROS interface. Services provided are:
To enable or disable the servo control of any joint.(message type: xarm_msgs::SetAxis)
To set operation mode. (message type: xarm_msgs::SetInt16)
* 0 for POSE mode, the robot will be position controlled. Trajectory will be planned by XArm Controller.
* 1 for SERVOJ mode, the robot will be commanded by servo_j function, fast & immediate execution like a step response, use this if user can generate properly interpolated trajectory.
* 2 for TEACH_JOINT mode, Gravity compensated mode, no position control.
To set robot state. (message type: xarm_msgs::SetInt16)
* 0 for READY/START state, robot must be in this state to perform any motion.
* 3 for PAUSE state, robot motion will be suspended.
* 4 for STOP state, if error occurs or configuration changes, robot will switch to this state.
Robot will go to home position with specified velocity and acceleration.(message type: xarm_msgs::Move)
Robot TCP will move to Caetesian target point with a straight line trajectory. Under specified Cartesian velocity and acceleartion. (message type: xarm_msgs::Move)
Given a set of targets, robot will move to final target through middle points, at each middle point, 2 straight-line trajectory will be blended with specified radius. (message type: xarm_msgs::Move)
Given all desired joint positions, and max joint angular velocity/acceleration, robot will move to joint space target. (message type: xarm_msgs::Move)
Used in SERVOJ mode, and if user have trajectory planned, call this service with high enough rate. Each trajectory point will be executed fast and immediately. (message type: xarm_msgs::Move)
Refer to RobotMsg for robot feedback information contents published through topic "/xarm/xarm_states".
Refer to CIOState for the gpio of the control box feedback information contents published through topic "/xarm/controller_gpio_states".
Last modified 1mo ago
