xarm_ros2
Note: This master branch is developed based on foxy
. In order to prevent users from getting code that does not match their ROS environment, this master branch will stop updating on 2022-11-22. It is only used for guidance, other branches will be updated normally. Please switch to the corresponding branch to use, sorry for the inconvenience caused, and thanks for your support.
foxy: https://github.com/xArm-Developer/xarm_ros2/tree/foxy
galactic: https://github.com/xArm-Developer/xarm_ros2/tree/galactic
humble: https://github.com/xArm-Developer/xarm_ros2/tree/humble
rolling: https://github.com/xArm-Developer/xarm_ros2/tree/rolling
注意: 由于此master分支代码是基于foxy
开发的,为避免用户获取到和ros环境不匹配的代码,于2022-11-22后此分支暂不再更新,仅仅用于引导,其余分支正常更新,请切换到对应分支使用,感谢您的支持,不便之处,敬请谅解
