Links
Description of the data structure used by xarm_ros2
msg
srv
    • xarm_api->service: clean_error
    • xarm_api->service: clean_warn
    • xarm_api->service: clean_conf
    • xarm_api->service: save_conf
    • xarm_api->service: reload_dynamics
    • xarm_api->service: set_counter_reset
    • xarm_api->service: set_counter_increase
    • xarm_api->service: clean_gripper_error
    • xarm_api->service: clean_bio_gripper_error
    • xarm_api->service: start_record_trajectory
    • xarm_api->service: stop_record_trajectory
    • xarm_api->service: ft_sensor_set_zero
    • xarm_api->service: set_linear_track_stop
    • xarm_api->service: clean_linear_track_error
    • xarm_api->service: open_lite6_gripper
    • xarm_api->service: close_lite6_gripper
    • xarm_api->service: stop_lite6_gripper
    • xarm_api->service: get_state
    • xarm_api->service: get_cmdnum
    • xarm_api->service: get_vacuum_gripper
    • xarm_api->service: get_gripper_err_code
    • xarm_api->service: get_bio_gripper_status
    • xarm_api->service: get_bio_gripper_error
    • xarm_api->service: get_reduced_mode
    • xarm_api->service: get_report_tau_or_i
    • xarm_api->service: ft_sensor_app_get
    • xarm_api->service: get_ft_sensor_error
    • xarm_api->service: get_trajectory_rw_status
    • xarm_api->service: get_linear_track_pos
    • xarm_api->service: get_linear_track_status
    • xarm_api->service: get_linear_track_error
    • xarm_api->service: get_linear_track_is_enabled
    • xarm_api->service: get_linear_track_on_zero
    • xarm_api->service: get_linear_track_sci
    • xarm_api->service: get_err_warn_code
    • xarm_api->service: get_linear_track_sco
    • xarm_api->service: set_mode
    • xarm_api->service: set_state
    • xarm_api->service: set_collision_sensitivity
    • xarm_api->service: set_teach_sensitivity
    • xarm_api->service: set_gripper_mode
    • xarm_api->service: set_gripper_enable
    • xarm_api->service: set_bio_gripper_speed
    • xarm_api->service: set_fence_mode
    • xarm_api->service: set_reduced_mode
    • xarm_api->service: set_self_collision_detection
    • xarm_api->service: set_simulation_robot
    • xarm_api->service: set_baud_checkset_enable
    • xarm_api->service: set_report_tau_or_i
    • xarm_api->service: ft_sensor_enable
    • xarm_api->service: ft_sensor_app_set
    • xarm_api->service: set_linear_track_enable
    • xarm_api->service: set_linear_track_speed
    • xarm_api->service: set_cartesian_velo_continuous
    • xarm_api->service: set_allow_approx_motion
    • xarm_api->service: set_only_check_type
    • xarm_api->service: config_tgpio_reset_when_stop
    • xarm_api->service: config_cgpio_reset_when_stop
    • xarm_api->service: motion_enable
    • xarm_api->service: set_servo_attach
    • xarm_api->service: set_servo_detach
    • xarm_api->service: set_reduced_tcp_boundary
    • xarm_api->service: get_tgpio_modbus_baudrate
    • xarm_api->service: set_tgpio_modbus_baudrate
    • xarm_api->service: get_gripper_position
    • xarm_api->service: get_position
    • xarm_api->service: get_servo_angle
    • xarm_api->service: get_position_aa
    • xarm_api->service: get_ft_sensor_data
    • xarm_api->service: set_pause_time
    • xarm_api->service: set_tcp_jerk
    • xarm_api->service: set_tcp_maxacc
    • xarm_api->service: set_joint_jerk
    • xarm_api->service: set_joint_maxacc
    • xarm_api->service: set_gripper_speed
    • xarm_api->service: set_reduced_max_tcp_speed
    • xarm_api->service: set_reduced_max_joint_speed
    • xarm_api->service: set_gravity_direction
    • xarm_api->service: set_tcp_offset
    • xarm_api->service: set_world_offset
    • xarm_api->service: set_reduced_joint_range
    • xarm_api->service: set_tcp_load
    • xarm_api->service: set_position
    • xarm_api->service: set_tool_position
    • xarm_api->service: set_position_aa
    • xarm_api->service: set_servo_cartesian
    • xarm_api->service: set_servo_cartesian_aa
    • xarm_api->service: set_servo_angle
    • xarm_api->service: set_servo_angle_j
    • xarm_api->service: move_circle
    • xarm_api->service: move_gohome
    • xarm_api->service: vc_set_joint_velocity
    • xarm_api->service: vc_set_cartesian_velocity
    • xarm_api->service: get_tgpio_digital
    • xarm_api->service: get_cgpio_digital
    • xarm_api->service: get_tgpio_analog
    • xarm_api->service: get_cgpio_analog
    • xarm_api->service: set_tgpio_digital
    • xarm_api->service: set_cgpio_digital
    • xarm_api->service: set_tgpio_digital_with_xyz
    • xarm_api->service: set_cgpio_digital_with_xyz
    • xarm_api->service: set_cgpio_analog
    • xarm_api->service: set_cgpio_analog_with_xyz
    • xarm_api->service: set_vacuum_gripper
    • xarm_api->service: set_gripper_position
    • xarm_api->service: set_bio_gripper_enable
    • xarm_api->service: open_bio_gripper
    • xarm_api->service: close_bio_gripper
    • xarm_api->service: robotiq_reset
    • xarm_api->service: robotiq_set_activate
    • xarm_api->service: robotiq_set_position
    • xarm_api->service: robotiq_open
    • xarm_api->service: robotiq_close
    • xarm_api->service: robotiq_get_status
    • xarm_api->service: set_tgpio_modbus_timeout
    • xarm_api->service: getset_tgpio_modbus_data
    • xarm_api->service: save_record_trajectory
    • xarm_api->service: load_trajectory
    • xarm_api->service: playback_trajectory
    • xarm_api->service: iden_tcp_load
    • xarm_api->service: ft_sensor_iden_load
    • xarm_api->service: ft_sensor_cali_load
    • xarm_api->service: config_force_control
    • xarm_api->service: set_force_control_pid
    • xarm_api->service: set_impedance
    • xarm_api->service: set_impedance_mbk
    • xarm_api->service: _set_impedance_config
    • xarm_api->service: set_linear_track_back_origin
    • xarm_api->service: set_linear_track_pos
    • xarm_planner->service: xarm_pose_plan
    • xarm_planner->service: xarm_joint_plan
    • xarm_planner->service: xarm_straight_plan
    • xarm_planner->service: xarm_exec_plan
action
Last modified 1mo ago
